Wrecked cv joint
piki
(Donor 2022)
x 5
Wrecked cv joint
Unread post by piki »
So i replace the cv joint on picasso c3 2012 diesel ,(passenger side), andwhen i put the cv joint back , i hammered it in wrong place , now i have clicking noise from this joint.
prob i damaged the bearing .
the local dealer says he cant find this cv join,and i need to replace the entire axle.
is he right is there any where i can get it online or something?
piki
(Donor 2022)
x 5
Re: Wrecked cv joint
x 6961
Both the ball joint kits are available from Citroen as well as the connecting rods, so I don't know where he is getting that from!
piki
(Donor 2022)
x 5
U mean cv joints?
im takling about the axle ,not steering...
x 6961
Ok, so if you are referring to the Driveshafts, then he is correct. Citroen do not sell the CV ball joints, only the complete left and right driveshafts.
x 1476
I've fitted one of these J&R CV joints - I couldn't believe how cheap they were, but it seemed to be good quality, and fitted well (*), and the boot was good. It ran happily for a good few miles before I had to scrap the car for other reasons.
Presume you fitted a new boot. Did you remove the joint, or use a stretch boot? Did you put plenty of grease in?
* my only trouble was that the supplied circlip was the wrong section and didn't fit in the shaft, so made getting the joint back on difficult. I had to straighten out and clean up the old clip to get it back on.
piki
(Donor 2022)
x 5
I reomoved the cv joint for replacing the boot, i grease it good i guess, but when i first time tried to put the joint back on i hammered it , when it didnt sat right so probebly, messed the bearing in it .
whould u recomend the J&R kit? the local dealer wants like 700 nis (215 USD ) to repair the axle....
piki
(Donor 2022)
x 5
also i can i know which picasso moddel i have , in the paper it says 1560 diesel 9hp.
in parts numbers there is this line- "1560cc 66KW 90HP"
, how can i know the Kw and HP?
x 1476
Post up your VIN and we can confirm.
x 6961
1.6 92 BHP DV6DTED from that engine code of 9HP (68 KW), but pop your VIN up and we'll let you know for sure.
piki
(Donor 2022)
x 5
Whats the Kw means ?
x 6961
Kilo Watts - its another measure of power output. Yours is about 68KW
piki
(Donor 2022)
x 5
ty ,appreciate the help
fyi - took the axle out (10 minuts at top) , 1 of the balls in the cv joint was loose , i send it to repair , hope it wont cost too much...
piki
(Donor 2022)
x 5
is there is any way to feel the joint ,when i put the joint back to the axle, to prevent what happened to me for future reference?
