2005 C4 petrol
Xander
2005 C4 petrol
Unread post by Xander »
It's about -12 celsius outside and my car wont start. First two times it worked with jump start. Next day it would not start again and jump start doesn't help. The ignition came on for about 2 seconds and then it only lighted up "economy mode".
I gave it a new batteri - did'nt help, the old battery also had 12,2 V...
I put on extra grounding from engine to body - then I got the egnition to light up but totally silence on the starter - no cranking.
I tried jum start again with extra ground and new battery - then the ignition only lighted up for 2 seconds again and it says "economy mode" again.
I took off jump start.Took on and off plus-cable - and ignition lights up again but silence starter...
I'm out if ideas... Mice-attack on cables? Haven't seen signs of that... Start-block off some kind? Transponder in key? Tried the other key...
x 6945
Re: 2005 C4 petrol
Are you sure you starter motor hasn't failed? If the battery is weak you should at least hear it trying to start before dying if it is the battery, but if the battery is good and you have tried with jump leads, then your starter motor may be dead. Sometimes tapping it with a hammer on the side of the starter casing can resolve it. If this is the case, amd it starts afterwards, then it's time to repair / replace the starter motor. It may take a few tries, but may be enough to get it working temporary or for a few more goes.
As the brushes in the starter wear down, they stop making electrical contact. Tapping the casing can sometimes knock the brushes back into place. But if this is the case it needs attention as it won't always work.
Xander
Re: 2005 C4 petrol
Today it was back to dark instrumentpanel just the "economy mode" light. If I turn the key back an forth many times the instrumentpanel can suddenly light up for 2 seconds then dissapear. It's some serious electric failure. All the big fuse's under the hood by the batteri are ok, all the big fuse's inside underside of dashboard are ok. The few times the instrumentpanel lights up there's not even a sigle click when I turn the key for start. Total silence. Batteri has 12,2 V
I'm selling it as rep-object. It isn't worth a visit to the workshop
