C5 X7 tourer rear tailgate trim
centurus2400
x 4
Unread post by centurus2400 »
Would you believe the rear wiper motor appears to have come loose from its moorings and I never know 'quite' where the blade will end up!
I've got as far as taking off the plastic covers and unscrewing the torx fasteners along the base of the trim, but would appreciate any advice on how i proceed from here.
x 6947
Re: C5 X7 tourer rear tailgate trim
Here you go:
{A}
Open the cover (1) (Rear wiper arm (2).
{B}
Remove:
  • The nut (3)
  • The rear wiper arm (2) using a wiper arm removal tool.
{C}
Detach the lower trim (5) (as "c") using a peg pliers trim tool [2].
Disconnect the connector (as "b").
Remove the lower lining (5).
{D}
Unclip the access hatches (1), (3) ( as "a") using trim removal tools.
Remove:
  • The access hatches (1), (3)
  • The covers (2)
{E}
Remove the bolts (4).
{F}
Disconnect the connector ( as "b").
Detach the rear screen wiper mechanism (4) ( as "a").
Turn a quarter of a turn the rear screen wiper mechanism (4) (following the arrow).
Remove: The rear screen wiper mechanism (4).
centurus2400
x 4
Many thanks for that - I think it can wait until a warm spring day though!
