Hydraulic hose connected to the rear height adjustment valve
navid
New User
Unread post by navid »
dear sir
I am writing the letter to get some information.i would be grateful if you help me.There is a forty cm wire in the hydraulic pipe connected to the Xantia sx 2000 cc ?suspension rear height adjustment valve.What is ?? the reason of using this wire?
your faithfully.
KennyW
x 165
Re: Hydraulic hose connected to the rear height adjustment valve
Unread post by KennyW »
Yes , the wire is inside the hydraulic pipe, I think is there to reduce the amount of lhm fluid flowing through the pipe thus increasing the pressure.
When I replaced the pipe with no wire and I didn't notice any difference in the hydraulics.
Kenny
C3 1.4 petrol (SWMBO)
x 3296
Somebody (I think it was Mandrake) suggested that the wire might help smooth out the fluid flow, eliminating the pulses generated by the LHM pump.
