ESP add / activation Jumpy 2013
kaupz
Unread post by kaupz »
Just bought used 8-seater Jumpy and now realised that ESP button is missing :(
can it be acticated with Lexia?
Some sensors need to add?
2.0 94kW Webasto, solar windscreen, parking sensors, Climate control, factory alarm and no ESP ?? at 2013 :D welcome to Estonia.
x 1052
Re: ESP add / activation Jumpy 2013
Unread post by wheeler »
If it wasn't fitted at the factory the minimum you would need to add is a new ESP type ABS block, a steering angle sensor & a yaw sensor. That's assuming all the wiring is present.
Unfortunately you cant just fit the button and activate it.
kaupz
ABS pump code is Bosch 0265232065 on the car
and google gives answers that it is also used for ESP ?
Yaw Rate Sensor location I can not find, to check if there is wiring ready.
x 6945
The Accelerometer sensor is usually fitted in the front centre area of the vehicle under the front centre console gearbox. Although the gear shift may be mounted on the dash, the Yaw sensor is usually near the location of the gear shift near the floor.
As for the ABS / ESP pumps, it is the ECU fitted on these and the software they incorporate that you also need to be concerned about, but will also need to make sure all the associated systems and ECUs and software are compatible as well as the programming. Not something I would tackle to be honest.
