Hi all, 4 years ago I changed the rear bearings on the xantia and all was well for years but lately the driver side rear bearing has been creaking.... it may be that time again.
Last time was here: viewtopic.php?t=55426&start=75
One questing though, at the time Mandrake mentioned the shims that you recover and refit to the thrust bearings. Last time though, they're were no shims and I'm now wondering if there should have been? Maybe that's why it's showing signs of failure after only 4years?
Does anyone have the dimensions that these shims use and how to check whether they are needed?
Xantia rear arm bearings again.
aerodynamica
- x 215
Graeme M
- x 1751
Re: Xantia rear arm bearings again.
Hi Graeme,
There is info about the shimming sizes in the Private Cars mechanic's booklets...
publication 1996_505960_AX_ZX_Xantia_XM (hit Xantia, 1996 in the table)
printed page 198
also similar (less detail) in 2001_050008_Xantia_XM_Evasion
printed page 219
Go to Members' Area > Resources for the pdf publications (downloadable and printable)
You'll need to make a forum donation for access (comes with Parts enquiries for this year and next - bargain!)
printed page 198
printed page 219
| A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
| Donate Further Information |
