Hi there,
I am experiencing a strange issue, the car at any givin random point decides to dump coolant out from the reservoir
We have performed multiple coolant pressure tests. The car holds pressure and not a single leak comes out.
Thus we cannot understand what is going on.
Can anyone shed some light on the issue, cause we are digging our head in.
Thank you very very much.
Thp 270 overheating
- x 1459
Re: Thp 270 overheating
Has the coolant been tested for combustion products?
Maybe an issue with the water pump drive wheel slipping?
Bruno R
How do you check for combustions products in the coolant?
Thank you very much.
- x 1459
There are test kits available, e.g. https://www.google.com/url?sa=t&rct=j&q ... u-hrUZ3Lxn
You can also get paper strips that you just dip into the coolant to check.
Bruno R
now this is clever.....xantia_v6 wrote: 17 Nov 2020, 18:10 There are test kits available, e.g. https://www.google.com/url?sa=t&rct=j&q ... u-hrUZ3Lxn
