Front blower,
Flanders
Front blower,
Unread post by Flanders »
Hi again all,
At present I've not got any blowers/heating in the front, I've removed fan, taken to work and ran 12v through the fan only and this works, so I've bought and replaced the matrix, but stil not working, my guessing is check wiring from fan connection back, is there a fuse for this as I can't find anything???
x 6946
Re: Front blower,
I can be several things:
1) There is a blower control module on these (resistance pack) that can fail.
2) Over time, the bearings in the blower motor itself can get stuck (water condensation). Because the blower control module only supplies stepped power, gradually increasing - when starting up it often doesn't have enough power to unstick the bearings. That's why when you applied full power to the motor when off the vehicle it was sufficient to get it going.
So it could be either the blower motor bearings sticking which will be an ongoing problem every time they are left for a while and seize again, or it will likely be a failed blower control module that has failed completely if not the bearings.
Flanders
Re: Front blower,
Thanks Marc,
Could you please tell me where the module is please
Andy
x 6946
Re: Front blower,
Hi Andy - I'd be happy to do this, but live parts data and parts diagrams require a min £10 Forum donation (which will cover you for up to 2 years for future requests), as PSA charge us for this data now from March 2020.
Details below - once you have done this, your member status will be upgraded automatically and I'll be able to get you the info.
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
