C5 X7 fuel filter housing
x 1240
Unread post by Peter.N. »
I have just fitted a new fuel filter because the engine would cut out if you pushed it hard, I don't so haven't had a problem but my wife used it who is considerably heavier footed then me and it died on her several times between here and Exeter.
So I fitted a new filter, the old one was covered in what looked like fungus and I had to empty the fuel out through the top as it wouldn't go through the element. Today we had an appointment at the optician, I got down to the village with no problem but as soon as we started going up the steep hill to the A35 it cut out and wouldn't start again, I ran backwards into the hedge unfortunately, not only completely blocking the road but I had to climb across and get out on the passenger side. :oops:
I did eventually get it to start but there were bubbles in the inlet pipe, anyway I managed to get back home and get the other car having phoned the optician and apologised for the delay.
The bubbles are not coming from the input but seem to be getting into the filter somewhere. I notice that there are several firms on ebay selling filter housings. Is this a known problem that I haven't heard about?
x 3565
Re: C5 X7 fuel filter housing
If it's the same filter housing as mine, then they have to be done up F.T. Are the two tabs (one on the lid, one on the body) lined up hard against each other ? The pipe-to-filter connectors can be a little troublesome as well as they ought to be lined up straight.
x 1240
Thanks. They are very tight to remove and replace, I tightened it up us far as it would go without breaking anything and the pipes were in line, I will check the tabs. Mine only has two pipes and a connector on the top, most of the replacements seem to have three, mine looks like the older pre X7 filter.
KennyW
x 165
Unread post by KennyW »
Peter'
I replaced mine and decided to get it from Citroen it was about £100 but it came with everything to fit.
My old one eventually would not seal due to the thread shredding in the housing. I've kept it think about re threading or drill out and using nut and bolt to secure.
The fuel lines are a PITA and can break when removing. Even had to replace one.
Kenny
C3 1.4 petrol (SWMBO)
x 1240
The thread on mine looks OK, I will take it apart and have another look. I'm going to park it with the back high up and see if I can find any leaks.
lexi
x 133
Unread post by lexi »
If there has been fungus in the system it may be prudent to put some biocide in the tank. That carry on with the hedge sounds like something out of Terry and June :shock: You are doing not bad getting out the passenger door. I can hardly get in the drivers door on those X7.......... :-D
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1240
I will bear that in mind, thanks. My wife helped pull me across the center console. :oops:
x 1240
This morning I had another look at the job and the sun was shining on the clear filter inlet pipe and I could just see a stream of tiny bubbles, so its not the filter, in fact since I changed it the problem is worse. I suspect that the fungi looking gunge in the filter is also in the fuel tank and since I changed the filter it's sucking even harder, hence the air.
I am trying to disconnect the two main pipes from the pick up/sensor assembly but can't get them off, I'm afraid of damaging them. They are different from the filter end which are just press-release, they seem yo have a small tab that you can pull up which then releases the 'u' section underneath, but having done that the pipes still won't shift.
What am I doing wrong?
