C5 1.6HDI 110
lexi
x 133
C5 1.6HDI 110
Unread post by lexi »
I have this estate atm. Not used in earnest yet. It had a seized and leaky injector. Managed to get it out renew seals and clean up. That is ok now. Oil and filter changed. Need to get round the car and find out whats what. Hopefully get up to David and Lexia it. The Vin is:
Does it have Eolys pouch or a container. 12OK on clock. It goes and pulls well.
Reason: Corrected VIN
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 6945
Re: C5 1.6HDI 110
You have a hard reservoir for the diesel additive Lexi, too early for a pouch system.
x 1240
Re: C5 1.6HDI 110
Unread post by Peter.N. »
If it's the same as the 2.0. its just in front of the o/s rear wheel under a cover.
x 6945
Re: C5 1.6HDI 110
It's on the Near Side Peter:
So when gravity filling make sure you are on the Near Side Ignore picture of Saloon - it's the same for the Estate.
x 1240
Re: C5 1.6HDI 110
Is it! I've done my red one and could have sworn it was on the o/s. I must be worse than I thought :?
lexi
x 133
Re: C5 1.6HDI 110
Peter.N. wrote: 22 Oct 2020, 17:26 Is it! I've done my red one and could have sworn it was on the o/s. I must be worse than I thought :?
This is a 6 plate, an old one. I bet you could get some MPG with this Peter.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 6945
Re: C5 1.6HDI 110
Hi, not that it matters :-D , but the OP has a MK II C5, not an X7, bur regardless they are all filled generally from the near side as the additive tank connectors are accessible only from this side when connecting up to the refill pipes. To do it from the other side would require a longer filling tube and would be quite awkward to see what is going on.
x 1240
Re: C5 1.6HDI 110
Oh right. I was visualizing my X7 and I was sure that the cover was on my left as I was sitting under the car looking toward the back. The other one needs doing now so I will have to re acquaint myself with it.
lexi
x 133
Re: C5 1.6HDI 110
What gearbox is in this guys? The one that isn't as strong as my previous 2.0 hdi? It feels treacly through the changes as though it has thick oil in it. I think this one whines in slow gears more, although all the mk 1's do it slightly.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 6945
Re: C5 1.6HDI 110
You have the BVM5 (BE4-5L) box on your 1.6 Lexi.
My 2.0 C5 MK II had the BVM6 (ML6 CL) box as does my current MK III X7 (although slightly updated).
lexi
x 133
Re: C5 1.6HDI 110
Any idea what spheres are on this Marc?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 6945
Re: C5 1.6HDI 110
Spheres:
I'm putting the genuine Citroen OEM (OEM) sphere part numbers first, followed by the Citroen cheaper versions (CHP).
Front Corners
OEM: 1638044180 (£147.11)
CHP: 1638380380 (£72.10)
Rear Corners
OEM: 1638044680 (£147.11)
CHP: 1638375780 (£61.60)
All prices from Citroen as of today inc. VAT.
No centre spheres on your vehicle Lexi.
lexi
x 133
Re: C5 1.6HDI 110
GiveMeABreak wrote: 31 Oct 2020, 11:12 Spheres:
Front Corners
Rear Corners
Thanks Marc. I was meaning the pressures mate :oops:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
