lexia for citroen
richard80
lexia for citroen
Unread post by richard80 »
I'm a new member I own a citroen xantia 1.8i forte abs light staying purchased a laptop with lexia already loaded I can get as far as putting in my model and vin number and that is as far as it goes I have used it on Peugeot van which was a bit newer than my xantia which is registered 2000 the is supposed to do older citroens .the system is lexia revision C diagbox 8.17 pp2000 has anyone any suggestions of why this may not be working not sure if the system is to up to date hopefully someone can help thank you richard80
admiral51
(Donor 2026)
x 391
Re: lexia for citroen
Unread post by admiral51 »
Hi and welcome to the forum.
I cannot help with your question but i would post it in the Diagnostic section of the forum, it may get lost amongst all the Citroen stuff.
Sure an Admin will be along to move it to the section but if you have a look in that section it may give you some info anyway
x 6957
richard80 wrote: 03 Oct 2020, 16:40 I'm a new member I own a citroen xantia 1.8i forte abs light staying purchased a laptop with lexia already loaded I can get as far as putting in my model and vin number and that is as far as it goes I have used it on Peugeot van which was a bit newer than my xantia which is registered 2000 the is supposed to do older citroens .the system is lexia revision C diagbox 8.17 pp2000 has anyone any suggestions of why this may not be working not sure if the system is to up to date hopefully someone can help thank you richard80
What version of Windows are you using and is it a 32 bit or 64 bit version of the Operating System?
richard80
marc sorry just been able to check for replys was suddenly taken to hospital .my version is 32 bit pro and laptop came preloaded with lexia I have tried getting on to the people who supplied the kit vehiclediagnosticsuk but my emails have been returned not sure whAt I can do now apart from write this off as a bad job kind regards richard
petarc1971
x 10
Unread post by petarc1971 »
Maybe that version is not stable, try to get a lower version, I had a similar problem.
richard80
thank you for you reply I will see if I can get some one to down load another version for me .I have tried tried vehiclediagnosticsuk who supplied the system but my emails to them have been returned not a good sign kind regards Richard
