Power steering oil pressure sensor switch
Gatwick56
Unread post by Gatwick56 »
Hi All
First post...I have a citroen xzara picasso 1.6 diesel manual 2006 model.
Recently the power steering stopped working, I have flushed the system and replaced fluid, I still have the problem at low speed and whenever parking.
I decided to purchase a power steering oil pressure sensor switch (hoping this might be the fault) however I cannot locate the sensor switch any help/ advice will be most welcome.
x 6955
Re: Power steering oil pressure sensor switch
Post up your VIN so I can see exactly what system you have. (VIN will be automatically masked from public view on submission, except to staff). This can also be down to a failing battery, either as a consequence of an aged battery, or if the alternator belt is slipping and not charging properly / or general charging issues, so don't rule that out.
Gatwick56
Vin number...VF7**************[VIN obfuscated, can be read by forum staff]
Thankyou for such a quick response.
x 6955
Ok, so with your VIN - ignore all that I said earlier as you have a mechanical falling out pump and only the petrol engines have a power steering pressure switch, which is probably why you can't find it.
Check the levels and that you have bled it properly:
Fill the power steering reservoir to the mark ( C) on the filler cap (4).
Engine stopped: Slowly move the steering, from lock to lock, in both directions (about 10 times).
Bleeding
Turn on the engine and let it idle for 2 to 3 minutes, without moving the steering wheel.
Keep the fluid level topped up.
Bleed the circuit by turning the steering several times in each direction.
Level
(H): Maximum level (engine warm).
(C): Maximum level (engine cold).
(ADD): Level minimum.
The oil level must be checked/topped up with the engine off.
x 1056
Unread post by wheeler »
All the steering pressure switch is for is to detect when you are on full lock to put the idle speed up a little to stop it stalling.
If it had failed all you would probably notice is a tendency for the engine to stall on full lock. I don't think I've ever known one to fail apart from leaking.
Is this the model with the reservoir on top of the pump?
Does the steering get a bit lighter if you hold the revs on a bit? If this is the case then its probably the sign of a weak pump. The ones with the reservoir on the pump were well known for it.
Gatwick56
Thankyou Administration & Wheeler for your responses and advice.
It looks like a pump replacement are any videos on this subject available on the forum?
