207 starting by itself
Daddi franski
Unread post by Daddi franski »
Hello Peugeot enthusiasts.
I have a problem with my 207 2007 Peugeot, it just started itself, in the home parking lot luckily,, :)
in gear it hit the house and stopped with windscreen wipers on full
not sure whether it actually fully started, or just cranked itself that one meter to the house.
locked - no remote start, keys in the house
Have you any idea what this could be?
any had this happen
Ignition?
Starter solenoid?
any advice
thank you kindly
Daddi Bjarna
Iceland
x 6957
Re: 207 starting by itself
Does the car have or has it ever had a remote starter system installed? This would not be uncommon in Iceland I guess. The car won't be able to run, but is obviously cranking. So something has either been miswired / changed (especially the ignition / battery terminal wiring), or it has a malfunctioning remote starter system I would suspect.
x 1943
Unread post by Paul-R »
Is it manual or automatic gearbox?
x 1056
Unread post by wheeler »
Id check the under bonnet fusbox for water ingress, Is the cover fitted correctly on it? there is a seal on it that doesnt work properly if it is not fully clipped down properly.
Does the car have stop/start system?
Daddi franski
GiveMeABreak wrote: 31 Aug 2020, 11:31 Does the car have or has it ever had a remote starter system installed? This would not be uncommon in Iceland I guess. The car won't be able to run, but is obviously cranking. So something has either been miswired / changed (especially the ignition / battery terminal wiring), or it has a malfunctioning remote starter system I would suspect.
Thank you, yes a remoter start would be a thing to look for, but it has not a remote start,,, not that I know of, only had it for 2 years now.
well worth checking again
takk
Daddi franski
Paul-R wrote: 31 Aug 2020, 11:48 Is it manual or automatic gearbox?
It´s a manual
Daddi franski
wheeler wrote: 31 Aug 2020, 12:30 Id check the under bonnet fusbox for water ingress, Is the cover fitted correctly on it? there is a seal on it that doesnt work properly if it is not fully clipped down properly.
Thank you, that´s a good point, the fusebox was shady when we bought it, will check it.
and no, not a remote that I know of - but worth checking again for it.
takk
Daddi
x 1056
By stop/start i mean does the engine auto stop when you stop at traffic lights & junctions then restart automatically when you go to move off?
x 1943
Was stop/start even available back in 2007?
x 6957
Certainly not on the 207
x 1056
Paul-R wrote: 01 Sep 2020, 10:06 Was stop/start even available back in 2007?
Stop/start was first available on the C3 as early as 2005. It had known fault where water got into the stop/start ECU (located next to the radiator) which caused the engine to crank by
itself, That was why I was asking, This was the model that used a reversible alternator instead of a starter motor.
My bet here is an issue with the under bonnet fusebox.
Daddi franski
wheeler wrote: 01 Sep 2020, 09:51 By stop/start i mean does the engine auto stop when you stop at traffic lights & junctions then restart automatically when you go to move off?
No, does not have that option
thank you
Daddi franski
wheeler wrote: 01 Sep 2020, 12:35
thank you, I will check the under bonnet fusebox this weekend, would be nice to figure this out
and hopefully not to expensive to fix
