gear ratios for Citroen c4 Picasso 1.6l hdi 6 speed egs
cargeeka999
Im having a bit of fun looking up the gear ratios of all the cars I have ever owned and I cant seem to find the gear ratios for the Citroen C4 Picasso 1.6l hdi 6 speed egs I used to own. Mine was first registered in 2007. Im hoping someone on here will know.
- x 6946
Re: gear ratios for Citroen c4 Picasso 1.6l hdi 6 speed egs
If this is for your current Picasso in your profile (DV6TED4) engine and piloted 6 Speed box, then look at the first column MCP/C, which should be yours:
Permission to now go and get a life please?
| Gearbox ratios | MCP / C | MCP / A | MCP / D | MCP / B |
| 1st gear | 13/46 | 13/46 | 13/46 | 13/46 |
| 2nd speed | 25/48 | 24/49 | 25/48 | 25/48 |
| 3rd speed | 31/41 | 30/43 | 31/41 | 31/41 |
| Fourth gear | 40/39 | 39/43 | 40/39 | 39/40 |
| Fifth gear | 46/35 | 42/37 | 46/35 | 45/37 |
| 6th gear | 52/31 | 47/35 | 52/31 | 47/32 |
| Reverse gear | 13/43 | 13/43 | 13/43 | 13/43 |
| crown wheel and pinion | 17 x 71 | 17 x 71 | 17 x 71 | 17 x 7 |
cargeeka999
Yes I was talking about that car, unfortunately I dont have it anymore it died so I stripped it for parts. Thank you.
This is what I got from it: https://www.dropbox.com/s/r300gb04xbfji ... o.pdf?dl=0
Reason: Removed Quote
- x 6946
Ok, so you only asked for the gear ratios; I do have speeds at 1000 RPM, as you can see the tyres make a slight difference, but those other figures are not quite right. These are the official ones:
| Tyres | 205/65 R15 | 215/55 R16 | 215/50 R17 | 215/45 R18 |
| 1st gear | 8,01 | 7,95 | 8,02 | 8,06 |
| 2nd speed | 14,77 | 14,65 | 14,79 | 14,86 |
| 3rd speed | 21,44 | 21,27 | 21,47 | 21,57 |
| Fourth gear | 29,08 | 28,85 | 29,12 | 29,26 |
| Fifth gear | 37,26 | 36,97 | 37,32 | 37,50 |
| 6th gear | 43,90 | 43,56 | 43,96 | 44,18 |
| Reverse gear | 8,57 | 8,50 | 8,58 | 8,63 |
- x 1941
Presumably as the table uses commas as the decimal separator, those are kilometres per 1000rpm?
cargeeka999
Thanks, mine was the 215/55R16 but I up sized the tyre to 215/60R16 so my car used to turn about 3% faster per engine speed.GiveMeABreak wrote: 23 Aug 2020, 09:48 Ok, so you only asked for the gear ratios; I do have speeds at 1000 RPM, as you can see the tyres make a slight difference, but those other figures are not quite right. These are the official ones:
Tyres 205/65 R15 215/55 R16 215/50 R17 215/45 R18 1st gear 8,01 7,95 8,02 8,06 2nd speed 14,77 14,65 14,79 14,86 3rd speed 21,44 21,27 21,47 21,57 Fourth gear 29,08 28,85 29,12 29,26 Fifth gear 37,26 36,97 37,32 37,50 6th gear 43,90 43,56 43,96 44,18 Reverse gear 8,57 8,50 8,58 8,63
- x 6946
Yes, they are.Paul-R wrote: 23 Aug 2020, 10:54 Presumably as the table uses commas as the decimal separator, those are kilometres per 1000rpm?
cargeeka999
OK I have altered things slightly so that now they should match the official speeds using the stock tyres 215/55R16 I also added the tyre size that I added to mine of 215/60R16: https://www.dropbox.com/s/r300gb04xbfji ... o.pdf?dl=0
