gear ratios for Citroen c4 Picasso 1.6l hdi 6 speed egs
cargeeka999
Unread post by cargeeka999 »
Im having a bit of fun looking up the gear ratios of all the cars I have ever owned and I cant seem to find the gear ratios for the Citroen C4 Picasso 1.6l hdi 6 speed egs I used to own. Mine was first registered in 2007. Im hoping someone on here will know.
x 6956
Re: gear ratios for Citroen c4 Picasso 1.6l hdi 6 speed egs
If this is for your current Picasso in your profile (DV6TED4) engine and piloted 6 Speed box, then look at the first column MCP/C, which should be yours:
Gearbox ratiosMCP / CMCP / AMCP / DMCP / B
1st gear13/4613/4613/4613/46
2nd speed25/4824/4925/4825/48
3rd speed31/4130/4331/4131/41
Fourth gear40/3939/4340/3939/40
Fifth gear46/3542/3746/3545/37
6th gear52/3147/3552/3147/32
Reverse gear13/4313/4313/4313/43
crown wheel and pinion17 x 7117 x 7117 x 7117 x 7
Permission to now go and get a life please? :-D
cargeeka999
Yes I was talking about that car, unfortunately I dont have it anymore it died so I stripped it for parts. Thank you.
This is what I got from it: https://www.dropbox.com/s/r300gb04xbfji ... o.pdf?dl=0
Reason: Removed Quote
x 6956
Ok, so you only asked for the gear ratios; I do have speeds at 1000 RPM, as you can see the tyres make a slight difference, but those other figures are not quite right. These are the official ones:
Tyres205/65 R15215/55 R16215/50 R17215/45 R18
1st gear8,017,958,028,06
2nd speed14,7714,6514,7914,86
3rd speed21,4421,2721,4721,57
Fourth gear29,0828,8529,1229,26
Fifth gear37,2636,9737,3237,50
6th gear43,9043,5643,9644,18
Reverse gear8,578,508,588,63
x 1938
Presumably as the table uses commas as the decimal separator, those are kilometres per 1000rpm?
cargeeka999
GiveMeABreak wrote: 23 Aug 2020, 09:48 Ok, so you only asked for the gear ratios; I do have speeds at 1000 RPM, as you can see the tyres make a slight difference, but those other figures are not quite right. These are the official ones:
Thanks, mine was the 215/55R16 but I up sized the tyre to 215/60R16 so my car used to turn about 3% faster per engine speed.
x 6956
Paul-R wrote: 23 Aug 2020, 10:54 Presumably as the table uses commas as the decimal separator, those are kilometres per 1000rpm?
Yes, they are.
cargeeka999
OK I have altered things slightly so that now they should match the official speeds using the stock tyres 215/55R16 I also added the tyre size that I added to mine of 215/60R16: https://www.dropbox.com/s/r300gb04xbfji ... o.pdf?dl=0
