So i have a 2011 c5 x7 3.0 HDI.
I had the stupid idea to retrofit the factory alarm into my car. Fortunetly every cable and connector were factory pre-installed. I just needed the sensors and modules.
After everything put into its place, i tried to trigger the alarm by the volumetric sensor but nothing (i waited the needed 45sec/5min). Plugged in my diagbox and manually activated the siren (that works), then i tested the volumetric sensor. Siren turned on, but not the blinkers. That made me think that i need to activate / enable the alarm.
Do you guys see from those screencaps why its not working properly?
Im thinking the first two pictures has the answer, but i wanted to ask here before i changes stuff.
Any help is appreciated!
