Hello i have a 2007 citroen c4 1.6 hdi automatic. The issues i believe are electrical but if you can point me in the right direction i would really appreciate it. Ever so often i lights on the dash appear with the word stop. The most common one is the temperature gauge over heating with the word stop. so i stop and then it goes back to normal operating temperature. Ive had it plugged in with various faults. it came up with the egr and the temp sensor so i had that replaced but the problems persist, still coming up with the egr, cooling and various others. it does not affect the way the car drives but its driving me mental. anyone had the same issue that could help. someone said possibly the ECU.
fault codes:
PO483
PO406
P1162
PO490
abs/ebd light on sometimes
Many thanks
Citroen c4 1.6 hdi automatic electrical fault
- x 6945
Re: Citroen c4 1.6 hdi automatic electrical fault
I'll need your VIN (it will be masked form public view on submission of your post automatically).
admiral51
- (Donor 2026)
- x 391
If you do the above it will be the best post you will ever makeGiveMeABreak wrote: 14 Aug 2020, 16:20 I'll need your VIN (it will be masked form public view on submission of your post automatically).
