Fuel line clips to Fuel Filter Broken C4 Grand Picasso 1.6Hdi 2011
conorsim
Unread post by conorsim »
When replacing the fuel filter part of one of the connectors on a fuel line broke. It currently still works but I will need to get it replaced. Anyone come across this before and what is the fix. Is it possible to replace the connectors, looks like it is removable but wanted to make sure before I tackle it.
Conor
x 6957
Re: Fuel line clips to Fuel Filter Broken C4 Grand Picasso 1.6Hdi 2011
It depends what fuel line your are referring to. The fuel lines are available from parts.
The Admin Team can help with live parts data and diagrams, but as PSA charge for this info now, we'll need a VIN and a min. £10 Forum donation that will cover you for up to 2 years of parts info and parts diagrams.
If this will help follow the links below and pop your VIN up:
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
