2 pin diagnosis
Cherrybomb 306
2 pin diagnosis
Unread post by Cherrybomb 306 »
Does anyone know where I can get our 306 2.0 8v diagnositic check with the two pin plug in the engine bay in the area of stoke on Trent cheers
x 1052
Re: 2 pin diagnosis
Unread post by wheeler »
Any decent garage with decent diagnostic kit should be able to do it, Bosch KTS for example comes with a universal harness adaptor for non 16 pin OBD connections. When the car is selected it will show you which pins to connect to. A lot of garages will also have conversion leads for older applications too.
Some Lexia/PP2000 kits cam with the adaptors too.
worst case you could just an adaptor, there are quite a few on ebay & not too expensive
https://www.ebay.co.uk/itm/Citroen-And- ... Sw-RFYs0B0
x 3296
Re: 2 pin diagnosis
My Lexia kit (from Easy Diagnostics) came with an OBD to two pin adaptor, so it could be worth asking any Forum members (in your area) if they have said adaptor, and then asking if they can help?
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
Cherrybomb 306
Re: 2 pin diagnosis
Thanks for the replies,we have ordered adapter so hopefully diagnose the lack of power and lurching under 2500 rpm
Cherrybomb 306
Re: 2 pin diagnosis
The adapter has arrived but the two OBD scanners that I tried won’t read the car so do I now need specialist Peugeot software.?
Mandrake
x 695
Re: 2 pin diagnosis
Unread post by Mandrake »
If you're referring to the 2 pin adaptor designed for a Lexia 3 and bundled with some Lexia/Diagbox kits, I think it's very unlikely that it would work with anything other than an actual Lexia, as two pin diagnostics don't use regular OBD-II comms.
A Lexia can switch into some proprietary comms modes which use non-standard pinouts which regular OBD-II adaptors do not understand.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
