Xantia Door locks
froggy
(Donor 2026)
x 4
Xantia Door locks
Unread post by froggy »
Hi, just changed both front door locks. The doors open from the inside only!!!! everything appears to be connected. should the rod that connects the outside handle to the lock be in a certain position? I am stuck! any help greatfully received Terry. :oops:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1055
Re: Xantia Door locks
Unread post by wheeler »
Do you mean the lock barrels & or the actual latch mechanism?
Its been a long time since ive been in about a xantia door latch but i think some of the rods are adjustable, the rods are threaded at one end to allow fitting in different positions.
Lightly push down on the arm that unlocks the latch to take up the play before fitting the rod. if its too loose you end up taking all the play when pulling the handle & it doesent push it enough to open the door.
froggy
(Donor 2026)
x 4
cheers, its the mechanism.
Terry
