As well all know,
There is an issue with the injector bolts on the 1.6 Hdi engines.
The get loose over time. This causes huffing/ticking etc.
What is the correct way to get this issue sorted? When the bolts are torqued - should it be done when the engine is hot or cold?
Can someone point me to or share with me - a guide that has been put together after much experience with this issue please.
I clearly have some oil/gunk deposits around injector 3.
Thanks,
Andle.
HDi - injector bolts - correct procedure
Andle
- x 4
- x 6945
Re: HDi - injector bolts - correct procedure
Officially, these are tightened using an injector tightening adaptor and Torque wrench with associated fitting:
| [8] Diesel injector tightening adaptor (-).1608.C | [7] Torque wrench (-).1608.A - (1 to 5 daNm) |
| Tighten the nuts (11) to 0,4 ± 0,04 daN.m using tools [7 - 9]. | Observe the following angular tightening method: Position the zero (marking " e") facing the operator Place the mobile index "d" opposite the gradation 65° Tighten progressively and in one single action bringing the mobile index "d" opposite the zero (marking "e") of the tool [8] Angular tighten to 65° ± 5° the nuts (11). |
discv
- x 24
This is exactly the point where it all starts to go wrong- time and again.
In my opinion based on painful experience, all the injectors need to come out. Keep them in the correct order. The injector seats in the head need a kiss and polish.
New copper seals all round and new injector tube seals. [Your no.3 seal will likely have burnt away already- hence the deposit]
Reassemble with a smear of very high temperature grease. I torque down with a inch/pound wrench- the threads of the stud and the nuts must be clean and lubricated to ensure your torque settings are true. For the angular tightening I used a printed and cut out protractor.
And now to the next hurdle. Again in my opinion- the sump needs to come off to inspect the the oil pick up gauze filter. And so on.....
C4 Grand Picasso 1.6 HDi 16V FAP/DPFS 110, -Auto (DV6 - 80kW) (C4) (DT) (2006-2008)
Toyota Aygo Black 2007 [well almost a french car!]
Xsara Picasso 2.0 Hdi Exclusive 2005
1220 GS Service Van RHD 1973
Andle
- x 4
Picasso xsara 1.6 hdi 2007.
90k miles.
Injector leak.
Tyres need doing, timing belt, and a pulley bearing in engine bay is squeaking.
Need need new tyres + tracking.
Is it worth fixing this car - or would i be better off buying a new car?
If I could keep the costs (exuding the tyres & tracking) below £500 - I would keep it. I just don't know how to make that happen.
90k miles.
Injector leak.
Andle
- x 4
Discv - do you do private work?
Where are you based?
discv
- x 24
I've got to chuckle- I'm an old gezzer confined to a wheel chair. And it took me about a year, crawling round on hands and knees to sort my 1.6 Hdi
On a serious note, doing a proper fix is a job that would cost a small fortune, so forget it unless your going to do the job yourself.
Selling it with declared faults would bring few buyers, I suspect. But if the body shell is rust free there my be more interest.
So you may be left with just one option- tighten all the injectors down to the 1 click of the wrist setting- and see what happens.
