Hi guys, my mums 208 1.0 is not blowing cold air through the air conditioning feature. The blower speeds work fine, hot and 'ambient' cold but no ice cold like before.
I was going to check the fuse, F29 but accessing it is very difficult and impossible through the hatch. What do I need to screw off to get in here and is it an involved job?
Ps. Any general things you advise to check with the AC I'm happy to hear. I changed the cabin filter about two months ago, doubt that could be causing no icy air though?
208 Access to Fuse Box
DSB1500
DS3 Prestige BlueHDI [120]
- x 6945
Re: 208 Access to Fuse Box
The A/C gas may need re-charging.
If it's too low on gas the compressor will switch off. To check, have the car idling and switch the A/C off, then open the bonnet and whilst watching / listening, get somebody to switch the A/C on. You should hear or see the the compressor clutch engage and the engine cooling fan kick in. If neither happens, then a lack of gas may be the issue. If the fan and clutch are kicking in, then you may just be low on gas if it is not as cold as it should be.
I don't think it will be the air mixer as you said you care getting some cool air and the hot, so more likely to be gas. Also, if the A/C system isn't operated at least once a month the seals can start to perish. If you do have a leak somewhere then moisture can get in and that is bad for an A/C system. Stone chips on the condenser radiator are a prime suspect for leaks.
May be worth getting one of those A/C services where they can test it for you.
DSB1500
Hey, I'll give this a go. Thanks. I usually hate taking our cars to mechanics, but with something like the A/C, I presume it can't be recharged at home?GiveMeABreak wrote: 06 Jul 2020, 19:38 The A/C gas may need re-charging.
In this case, is it important that it's a Peugeot dealer or can any mechanic / car workshop do this just as well? Thanks
- x 3296
I would suggest you take it to a proper mechanic, and not somewhere like Halfords. If the mechanic know what they are doing they will follow the full procedure (Halfords usually just add extra refrigerant), which basically evacuates the gas/lubricant from the system, holds a vacuum on the a/c system for a while (to check for some leaks (this doesn't find all types of leaks)), adds in new lubricant, refrigerant (and, possibly, U/V dye which helps for future leak searches) to the correct quantities for the vehicle in question (which can depend on various vehicle specific parts) as well as a few other things. Although he is not in your area DickieG (forum member) fully understands what needs to be done, and (if you PM him) may explain (although he has not been 'active' on the forum for a while).
- x 6945
There are quite a few places that do air conditioning services or simple top ups. It depends on what you want.
A full service will vacuum everything out, disinfect the system and the replace with the correct oil and gas quantities. This is a bit more time consuming of course - but they have a machine that automates the process. A top up will just recharge the gas according to the A/C system and capacity fitted to your vehicle (so it is important that you know this before hand so you can check they are getting it right).
Kwik fit are quite good - as again it's the machine that does it all while you wait.
