Xantia MK II - Worn upper bearing of the steering column
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
The upper bearing of the steering column in my MK II Xantia is worn , causing the steering wheel to rattle. What is the replacement bearing ? Is there any thread describing how to replace the bearing ? As long as I remember I once saw a website that describes the procedure and what is the replacement bearing. It was an after market bearing ( I think SKF ) - Citroen do not specifies the part number nor the procedure. I searched over the web and could not find it.
Reason: Title spelling
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Xantia MK II - Warn upper bearing of the steering column
Any help with this
x 2938
The factory recommendation is that if any wear is found the column should be replaced completely.
I'd guess that a good mechanic would find a fix without that expense but it needs a close look to see what's involved
Some columns have a bronze bush others a felt bush both of which can be replaced by a competent fitter.
Is the steering wheel bolt tight? I've seen rattles caused by it not being properly tightened.
lancia58
(Donor 2022)
x 8
Hi
The steering wheel bolt is tight. I have seen in the past a web page that refers to the problem. It is the top bearing . I can not find this page again. It described how to replace the bearing and the replacement bearing from SKF. Some fixed by tapping the bearing after removing the steering wheel
ksanturion10
x 19
Unread post by ksanturion10 »
lancia58 wrote: 20 Jun 2020, 13:30 The steering wheel bolt is tight
It is tight enough for Hex Socket 21 mm, but not that tight. Maybe a helper, holding the wheel, will be needed, and also a long pipe as a lever for the socket arm.
I've red that many people had hit themselves with the wheel, when trying to pull it out... I also hit myself the first time :-D...the secret is to left the nut screwed at the end ;)
Only himself the stupid makes wrong, many are being confused by the clever :P
