Need help Gearbox faulty
Mikeodhis
Unread post by Mikeodhis »
Hi, I have a Peugeot 207 2010.with the piloted manual gearbox(sensodrive) .i recently changed the clutch kit because is was completely worn. Now I have a error code p1795 and I can’t seem to get what the problem is. Kindly help.
x 6945
Re: Need help Gearbox faulty
Hi and welcome.
P1795 is a coherence fault with the gearbox Counter Information. It means that the number of engagements and disengagements of gears has exceeded 1000000 cycles.
So could be that either the actuator needs replacing or the system needs programming.
Mikeodhis
Thanks Mark.ill look into that
