Need help Gearbox faulty
Hi, I have a Peugeot 207 2010.with the piloted manual gearbox(sensodrive) .i recently changed the clutch kit because is was completely worn. Now I have a error code p1795 and I can’t seem to get what the problem is. Kindly help.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Re: Need help Gearbox faulty
Hi and welcome.
P1795 is a coherence fault with the gearbox Counter Information. It means that the number of engagements and disengagements of gears has exceeded 1000000 cycles.
So could be that either the actuator needs replacing or the system needs programming.
Thanks Mark.ill look into that
