Citroen synergie sump plug washer
tony1976
Unread post by tony1976 »
Hi Forum,
does anyone know the correct sump washer size for my citroen synergie 2.0 hdi 2002
i see there various sizes and im a bit confused as to which one i need.
x 1240
Re: Citroen synergie sump plug washer
Unread post by Peter.N. »
I have only come across two basic sizes for PSA engines but may be more, I keep a stock of both. If you want to do an oil change the chances are that it won't leak with the original and you can check it for next time. What usually makes them leak is excessive tightening, if it comes undone fairly easily it should go again.
Alternatively if you loosen it two or three threads you might be able to get calipers on the bolt or the outside of the washer, if you can get either of those measurements I can probably tell you the size.
x 1746
Washer (probably copper) is either
14 i.d. × 21 o.d. × 2mm thick
or
10 × 21 × 1.5mm
it says on a bit of paper I have here.
x 1240
Thanks Chris.
Don't buy them from the dealers, you can get a packet of them on ebay for what they will charge you for one.
tony1976
Ok so My old one is 14 i.d. × 21 o.d. × 2mm thick
eBay here I come!
Thanks for all your help everyone
x 1240
You're welcome. :)
moizeau
x 423
Unread post by moizeau »
Go for the ones with a rubber insert.
Pete
x 1746
They're called Dowty washers, and very good they are too.
x 5671
I am using them as the place I buy my junk from had none of the usual type. Last ages.
tony1976
Is it the m14 size I need as the inner diameter of my old one is 14mm??
Steve Walsh
x 518
Unread post by Steve Walsh »
If you have the solid copper type and can't get hold of a replacement. You can anneal (soften) the old one and re use it.
Heat it to red hot on a gas torch, or cooker and drop into cold water.
x 1746
tony1976 wrote: 11 May 2020, 06:46 Is it the m14 size I need as the inner diameter of my old one is 14mm??
That's the one.
x 1240
https://www.ebay.co.uk/itm/200pcs-M5-M1 ... SwmZFZo7Oo
They should last you for a few oil changes.
