particle filter additive too low 2010 3008
colinsunderland
x 3
Unread post by colinsunderland »
Hi all, just joined.
Just got the error message above tonight,
from reading through the forum it seems its either a bag or a tank, is there any easy way of telling, and are they easy to refill? (The engibe fault appeared at the same time so presume its that)
I also think the ECU needs resetting using Diagbox, would a snapon diagnostic kit do this or only Diagbox does anyone know? I have access to a Snapon one, but would have to buy Diagbox/Lexia. I was thinking of doing that anyway as I think one of the injectors is on its way out, are the kits from Ebay ok to use? I looked at EasyDiagnostics but they aren't selling cables at the moment, and the software isn't much use without one :(.
As the warning has just came on, I presume it will be ok to use for now, especially as I'm only doing about 50 miles a week?
How good will Diagbox be for diagnosing the injector problem? Is it easy enough to use? Or is there anyone local to me who has it and could diagnose the problem (and reset the additive counter at the same time)?
Thanks in advance for any help
Also, for admin, when I was registering I got an error saying 'the entered email domain has no valid MX record', thats from a 20 year old domain and had to switch to using a hotmail account.
x 3296
Re: particle filter additive too low 2010 3008
Hi, and :welc: to the Forum.
x 6945
Hi Colin.
Diagbox and the VCI hardware are used exclusively by PSA for all their vehicles. Some professional level diagnostics should be able to reset the Additive Counter - as long as they are able to talk to your 3008 and have the correct capabilities.
Watch out for cheap units on ebay - many of these are not likely to have the full chips and other components on the boards, so have issues talking to full CAN vehicles and that will be a waste of time. Get a full chip, revision C kit.
Your engine diagnostic light will very likely be referring to the additive warning.
The additive levels are not physically measured, but are estimated. It works out the distance remaining before the vehicle is due to be serviced from your maintenance counter and if it thinks there is insufficient additive before maintenance, it will put the light up as a warning.
You can continue to use it for now, but be wary. When you get the next warning it will be the risk of clogging or similar - this is when regenerations are not happening and the clogging will get worse, to the point where it can't regenerate any more and will have to come off for a deep clean.
Here's a post with members willing to help and a link to a Google map at the end showing their locations. Bear in mind this is unlikely to happen presently given lockdown tough.
viewtopic.php?t=56452
Yes, Diagbox will be able to do diagnose injector problems and give you live data - it is designed to work with PSA vehicles.
colinsunderland
x 3
Thanks for the fast reply :)
The SnapOn kit can do quite a bit, read my parking sensor fault which the cheap ones, and a couple of quite expensive ones didn't, so hopefully it can do it, but will be next week before I can get it plugged in to find out. Just thought, if I couldn't, I could grab one from ebay :), just had a quick look and the ones you mention start from about £60 so not loads more anyway :) Do you know if EasyDiagnostics usually sell them?
I'm not going to leave it ages, but obviously at the moment its quite hard to get work done, so was thinking if it wasn't hard I would do it myself, if the car needs putting on a ramp I can get that easily enough. Is there any way of telling of its the bag type I need to buy or if its the the tank that you refill?
x 3296
Easy Diagnostics kit is well worth considering (I have an earlier version). They have the full opto coupler set (which some of the cheaper clones don't), so should work with most PSA vehicles. There is a procedure whereby forum members can get a discount;
https://www.frenchcarforum.co.uk/forum/ ... hp?t=60113
If you may be helping friends with PSA vans you might want to get the extra S1279 module.
EDIT; I have just gone to their website and they currently are not taking any orders for equipment (based on government advise).
x 6945
colinsunderland wrote: 30 Apr 2020, 22:05 Thanks for the fast reply :)
That will depend on model, year and engine. Your VIN will let us know which type you need. If a bag - don't bother trying to refill as it is messy and the liquid is highly toxic and carcinogenic. The refill pouches just go in and job done after the reset. If a tank, then you don't need a ramp, but you'll need to gravity feed it from the filling kit - just be supporting the bottle on a stand or similar. You can buy the kits and some come with the filling kit.
colinsunderland
x 3
Thanks very much for everyones help so far. Theres someone with Lexia not far from me so have sent him a PM, but hasn't been on since November so hopefuly he's still active :)
My VIN is VF3**************[VIN obfuscated, can be read by forum staff]
thanks again :)
x 6945
Ok, so you have the hard reservoir tank - no pouch.
colinsunderland
x 3
thanks very much, I've searched but can't find any guides, is there one you know of?
x 6945
Your build date is 12519, so you should have blue click fit connectors on your additive tank. You need to use Powerflex additive for this build date, not infineum F7995 or Eolys 176.
Here's a general guide (the tank location may be in a slightly different place):
colinsunderland
x 3
Is this the right one?
https://www.ebay.co.uk/itm/PEUGEOT-CITR ... Swx6pduARj
Any idea how big the tank is please?
Thanks again for everyones help :)
x 6945
I would not get anything unbranded - it looks like that seller is filling bottles themselves - you don't know what you are getting - avoid!
If going for the Walker alternative that is cheaper than the OEM stuff, you need Walker 80620: Here's a 3 litre kit. It's from Poland, and includes free postage. The OEM stuff will be about £180+, but the walker here is £107
https://www.ebay.co.uk/itm/PARTICULATE- ... 3249030855
colinsunderland
x 3
thank you :)
colinsunderland
x 3
Just wanted to double check before I order that Powerflex is correct (assuming I took a photo of the right bit :)
Thanks to everyone who helped :)
x 6945
Powerflex is the correct additive for your build date. If you attempt to put the older additives in, you will very soon brick the additive system as the older DPX42, Eolys 176 and Infineum F7995 are not interchangeable with Powerflex.
The click-fit connectors are / were coloured - but this is unreliable due to production switch over to other systems - so always go by the build date and this is correct for your VIN.
