Part number needed please
Benscab123
x 3
Unread post by Benscab123 »
Could anyone tell me the part number for the fuse box on top of the battery please ? Thank you.
Benscab123
x 3
Re: Part number needed please
I’m getting multiple fault codes and thinking it’s probably fuse related. So if someone could point me in the direction of the most likely culprit I’d appreciate it.
x 1746
Yes, we can get that part number for you.
Please post your VIN so we can get the correct one.
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
Benscab123
x 3
My vin number should already be on here for admin to see
x 1746
Sorry, but 140+ posts is a lot to sort through!
Benscab123
x 3
Sorry didn’t realise how it worked , I’m not with the car at the moment but the post title where the vin number can be found is “ Additive not working “. Hope this helps.
x 1746
Have the VIN now - VF7**************[VIN obfuscated, can be read by forum staff].
Benscab123
x 3
Did you find the part number ?
x 1746
We will need a forum donation (see above) before doing the part number search.
Just hit Donate in the box above.
Thanks.
x 1052
Unread post by wheeler »
What makes you think there is a problem with the fusebox on the battery? The one on the battery is literally just a fusebox as far as i can tell. Literally just a busbar with some fuses attached.I can’t think what could go wrong with it apart from poor connection at the fuses which could normally be sorted out with some cleaning.
x 6945
The engine fusebox (PSF1) doesn't just hold the fuses, it has 2 parts to it:
Module 1 contains the maxi fuses
Module 2 contains an electronic card, the relays and fuses.
Its function is listed as:
  • Distributing the electrical supplies under the bonnet
  • Switching of certain actuators under the bonnet
  • Transferring of power to the passenger compartment fuse box, built-in systems interface
  • Communication on the BODY CAN
  • Permitting the acquisition of the signals from sensors under the bonnet
x 1052
Are we talking about the same fusebox here? The OP has said the fusebox on top of the battery. The PSF1 (or BSM)is the under bonnet fusebox unless im reading this wrong.
Benscab123
x 3
I’m really in the dark on this. I’ve no idea where to go with it. Is there anyone knowledgeable close to me that could maybe have a look at it for me please ?
I’m in Bridlington on the east coast.
x 1938
Unread post by Paul-R »
A photo with an arrow or other pointer might help!
x 1746
Yes - please post a photo so we're clear which part you're thinking of replacing.
