Test, low temp solder wire connectors with heat shrink
- x 1983
- x 1751
Re: Test, low temp solder wire connectors with heat shrink
Handy at the roadside, if you've remembered to bring your 12v heat-gun with you!
- x 8052
One of those quite interesting ideas that may be handy but for temp repairs chocolate block and tape is far more versatile and probably a lot cheaper!! Then when you get home a proper solder joint with traditional heatshrink is clearly a better permanent repair.
- x 5645
Why do you need to heat-shrink your butt?
- x 8052
Stops SWMBO moaning!
- x 5645
