Hi
I want to change the cushion and backrest covers. I have Citroen instruction for this job-but it is not cleat enough. I removes the seat shell and start taking the seat apart. The cushion is relatively easy to change. For changing the backrest I need to detach the airbag and I am not sure how to do it. The Citroen instruction does not mention removing it. Any help is wellcome
Citroen C4 VTS - Stripping front seat - removing airbag
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 6955
Re: Citroen C4 VTS - Stripping front seat - removing airbag
The side airbags are rivetted in place! You will need to drill it out and must rivet it back for safety reasons.
Why not just put an airbag-compliant seat cover over the seat?
lancia58
- x 8
I was able to detach the airbag . It were two nuts that that secures the airbag to the seat frame
- x 1990
Would rivets pass the "secure fixing" test for an explosive device ? Only stripped 3 seats with airbags, always nuts on studs
