Citroen C4 VTS 180 - Wiring question
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I have a LHD Citroen C4 VTS 180 make year 2006. I removed from the car after market installation of alarm, speakers and anti theft device . I had to re-wire wires at the internal fuse box that were cut when the mentioned devices uninstalled.
I left with one wire circled int he following picture I didn't fine the other end of the wire. It is strange to me since the wire is thick and is should be easy to fine the other hand, or it was a free wire maybe with a connector on the end that someone cut it. Any body can help with this
The following connector was also free , I guess it is intended to an option that is not installed in the car. Someone knows what it was intended to ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1056
Re: Citroen C4 VTS 180 - Wiring question
Unread post by wheeler »
If its an original wire it should have a code printed on it every couple of inches, its not usually more than 5 digits & can be a mix of numbers and letters. This code can give a clue.
x 1438
Unread post by xantia_v6 »
That blue connector looks like one for an optional bluetooth hands-free kit.
lancia58
(Donor 2022)
x 8
xantia_v6 wrote: 09 Apr 2020, 21:31 That blue connector looks like one for an optional bluetooth hands-free kit.
Isn't the optional bluetooth hands-free kit is RD45
x 1438
Yes, from about 2013, but before that there was an add-on box for the RD4.
x 6955
lancia58 wrote: 10 Apr 2020, 07:07
The later RD45 has Bluetooth built in to the Head Unit - no additional kit needed apart from a compatible Multifunction screen that may be needed if not already fitted - and microphone wiring if it is not already there in the Head Unit block.
lancia58
(Donor 2022)
x 8
wheeler wrote: 09 Apr 2020, 20:49 If its an original wire it should have a code printed on it every couple of inches, its not usually more than 5 digits & can be a mix of numbers and letters. This code can give a clue.
I had to take to pics to get the printed code it looks like it is KX:01 57 04/04 * B H4 0* .
I hope this can help
x 1056
All I can find is that wire BH40 is a battery live supply. Best to make sure the end is insulated.
lancia58
(Donor 2022)
x 8
I insulated it. Since it is thick it makes sense that it is battery live supply - can you check if there is a connector on the end ? I'll check with a multi meter if it is power ? Maybe it was used for some after market installation and this is the reason it is cut and the reason that I can not find the other end ?
lancia58
(Donor 2022)
x 8
wheeler wrote: 10 Apr 2020, 16:38 All I can find is that wire BH40 is a battery live supply. Best to make sure the end is insulated.
I checked the wire and there isn't a 12V regardless if the ignition switch is on/off.
x 5662
lancia58 wrote: 11 Apr 2020, 12:32
There are some items that are only active when the engine is actually running - to safeguard the battery from being depleted. Fans being just one example.
lancia58
(Donor 2022)
x 8
I also checked for 12v when the engine was running .
lancia58
(Donor 2022)
x 8
On Citroen C4 UK I have been told that it is a 12v cable that goes to the boot. It's not live. It's intended to be used when connecting a trailer relay or an audio system in the boot.
