Oil Level Measurement is invalid
heshamderbala
Unread post by heshamderbala »
Hi
When i start my car i see a message saying oil level measurement is invalid i went to check the battery however it is 5 months ago purchased it is ok and nothing in the power what could be the problem i went to the service center and they checked by the software they have and nothing giving error
Hesham
Hesham
heshamderbala
Re: Oil Level Measurement is invalid
My car is c4 Grand Picasso 2015 new shape
Hesham
x 1484
Unread post by xantia_v6 »
I think that error can be caused if the engine oil level is too high. What is the oil level on the dip stick?
heshamderbala
Hi
Will check in the morning and tell you but what if it is above max could do so. And what is the solution for that also i think the computer could say that or iam wrong.
Hesham
x 1955
Unread post by Paul-R »
I had the same message on my C5 four years ago. I detailed it here https://www.frenchcarforum.co.uk/forum/ ... =3&t=55464 - mostly on the first page and some more relevant posts on the third page.
You don't say what engine you have. Mine is the 163bhp 2.0Hdi.
x 6950
He has a petrol EP6FDT M.
The level read will only be correct if the vehicle is on level ground and the engine has been off for more than 30 minutes.
heshamderbala
Hi
The car was switched off all the night and the car is parked on a level ground.
However i went today to the service center and they told me that the sensor needs calibration and initialization, then asked me to check today and revert back to them if it appears again
Hesham
heshamderbala
Hi
Thanks for your help the problem solved as i said it was calibration and initialization for the oil sensor
Hesham
bahcekapili
x 9
Unread post by bahcekapili »
Dear friends,
I got this message two weeks ago on my Citroen C5 2.0 HDI Exc. car. No DTC detected with FAP or Lexia. I cut the power from battery for 6 hours and after three start stop of the car it was ok.
Because I cut the electric U1218 (one of the parameters present in a datastream sent by the BSI is invalid) came on i think. At the beginnig i cleared the DTC by FAP but as soon as ignition on and off it appared again. I look some descriptions and found that at least 5 minutes of driving is necessary. After that all went ok and DTC gone away.
But as doing this procedure i saw that FAP life left value increased to 240.000 km. Before it was 223.500 km and other parameter "Deposits in FAP" value set to zero. Before it was 6 g.
I wish all of you non problem cars.
