What to do with an unwanted ES9J engine ?
x 1997
Unread post by Stickyfinger »
any thoughts ?
(no coffee tables :))
x 8141
Re: What to do with an unwanted ES9J engine ?
Was it a runner and is it complete?
x 1997
Yes and yes
x 3296
Could you shoehorn it into Daffodil? That would be an interesting project!
x 1997
Daffodil has been sold....hence the engine is unwanted :)
x 3296
Then you need to update your Cars list. Still, it would have been an interesting project (and WOW would she have surprised boy racers in their hot hatchbacks!).
x 8141
You could remove the sump and the heads, then turn the engine upside down, replace the flywheel with a crank handle and you have a ready made 6 pot potato masher!! :)
x 1997
That's a new one |:)
x 3565
Knowing how you're such a keen greenie :-D You could supply your own electricity needs with a domestic wind turbine, and you could shove a propeller onto the engine and use it to create a suitable wind for those days when there's no wind blowing. Simple :)
x 8141
bobins wrote: 16 Feb 2020, 20:39 Knowing how you're such a keen greenie :-D You could supply your own electricity needs with a domestic wind turbine, and you could shove a propeller onto the engine and use it to create a suitable wind for those days when there's no wind blowing. Simple :)
Even simpler, you could just point the exhaust at the wind turbine and do away with the propellor :-D
x 1997
I was thinking add two turbos and 24 alternators :)
x 1470
Unread post by xantia_v6 »
A BX with a seized engine needing TLC? https://www.ebay.co.uk/itm/1989-Citroen ... r=1&_rdt=1
x 1746
That just has to be saved. Same year, colour, interior as ours was. If I were in UK, I'd be jumping at that, and fitting an XUD9 — or even an EV project. ES9 though, Mike??
x 1997
BX is too narrow for the engine/gearbox....
x 5674
There was someone asking a couple of days ago why Tesla don't fit a turbine and generator on the roof so they never run out of electricity.*
James frequently says that there are no stupid questions but I think that is an exception.
*not anyone here, fortunately.
