(no coffee tables
What to do with an unwanted ES9J engine ?
- x 1998
any thoughts ?
(no coffee tables
(no coffee tables
- x 8084
Re: What to do with an unwanted ES9J engine ?
Was it a runner and is it complete?
- x 1998
- x 3303
Could you shoehorn it into Daffodil? That would be an interesting project!
- x 1998
Daffodil has been sold....hence the engine is unwanted
- x 3303
Then you need to update your Cars list. Still, it would have been an interesting project (and WOW would she have surprised boy racers in their hot hatchbacks!).
- x 8084
You could remove the sump and the heads, then turn the engine upside down, replace the flywheel with a crank handle and you have a ready made 6 pot potato masher!!
- x 1998
That's a new one |:)
- x 3566
Knowing how you're such a keen greenie
You could supply your own electricity needs with a domestic wind turbine, and you could shove a propeller onto the engine and use it to create a suitable wind for those days when there's no wind blowing. Simple
- x 8084
Even simpler, you could just point the exhaust at the wind turbine and do away with the propellorbobins wrote: 16 Feb 2020, 20:39 Knowing how you're such a keen greenieYou could supply your own electricity needs with a domestic wind turbine, and you could shove a propeller onto the engine and use it to create a suitable wind for those days when there's no wind blowing. Simple
- x 1998
I was thinking add two turbos and 24 alternators
- x 1449
A BX with a seized engine needing TLC? https://www.ebay.co.uk/itm/1989-Citroen ... r=1&_rdt=1
- x 1751
That just has to be saved. Same year, colour, interior as ours was. If I were in UK, I'd be jumping at that, and fitting an XUD9 — or even an EV project. ES9 though, Mike??
- x 1998
BX is too narrow for the engine/gearbox....
- x 5671
There was someone asking a couple of days ago why Tesla don't fit a turbine and generator on the roof so they never run out of electricity.*bobins wrote: 16 Feb 2020, 20:39 Knowing how you're such a keen greenieYou could supply your own electricity needs with a domestic wind turbine, and you could shove a propeller onto the engine and use it to create a suitable wind for those days when there's no wind blowing. Simple
James frequently says that there are no stupid questions but I think that is an exception.
*not anyone here, fortunately.
