C5 starting
Ade82
C5 starting
Unread post by Ade82 »
Hi, I'm new to the forum so please bear with me, I've gone to my Citroen C5 estate 2006 1.6 HDI this morning it started then immediately cut off now won't start, the ignition is turning over I have the correct lights on the dash waited for the coil lights as normal no warning coming up just won't start tried jump start from another car still won't kick in. Please can anyone advise?
x 6954
Re: C5 starting
Hi and welcome.
Fuel starvation? How much fuel is in the tank? In either case you really need to get it diagnosed for a fault code. It will be guess work without it. If you have breakdown cover with home start, they should be able to plug in and get any fault codes - when you do pop them up here and we can help you with the problem.
leithant
x 9
Re: C5 starting
Unread post by leithant »
Fuel pump, fuel pump relay, filter?
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
citroenguy
(Donor 2021)
x 75
Re: C5 starting
Unread post by citroenguy »
How's the fuel rail pressure?
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
