Timing belt replacement, crank pin hole diameter
David_CH
Unread post by David_CH »
Hi !
i've asked an official Peugeot reseller how much it will cost to replace my timing belt. Answer : 1500 chf (= 1395 eur = 1177 gbp) :shock: :shock: :shock:
It's a little more than my actual budget, so i'll try to do it myself. It's not rocket science if i follow the important security things like the locking of the crank and cam pulleys.
I can build the pins myself with a lathe, but i have to measure the holes first.
So i am asking here if someone has already done that before me, to build the pins necessary for the job, or if i can find this information on the service manual.
Btw, my engine is a EW10J4
x 5674
Re: Timing belt replacement, crank pin hole diameter
I bet you could drive to Poland, have a bit of a holiday there and have the belt changed all for less than that.
x 1487
You should be able to buy a set of pins quite cheaply, e.g. here, in the UK
This shows the dimensions of the crank pin:
x 6957
You might want to do the tensioner rollers too whilst at it.
David_CH
Thank you all for your precious help !!
Yes Marc i'm buying the whole SKF kit (belt+pump+rollers)
Jackie i will consider your idea about Poland holiday ;-)
David_CH
Does the timing belt retaining clip is essential ? or i can use a plastic tie strap to keep it in position ?
