Berlingo 1.9d won't start
Bullet1977
Unread post by Bullet1977 »
Hi I'm wondering if anyone can help.
2003 dw8 engine 130k. Was driving it and come to a stop and it cut out. I had to bump it down a hill and it will only run if throttle all the way to the floor and would try to die if anything other than full throttle. I limped it home and now will not start. I think I have eliminated the egr and fuel filter looks ok. Any other ideas?
Thanks in advance
x 1056
Re: Berlingo 1.9d won't start
Unread post by wheeler »
Check the vaccum operated throttle butterfly on the air inlet on the inlet manifold, the little arm can detach & flap moves about loose & blocks the air intake.
