C5 Brakes
rogerc5
C5 Brakes
Unread post by rogerc5 »
HI folks
Just a quick one..
My garage has replaced a front Caliper, and since then the brakes feel different.
They work OK with gradual take up as usual, but I notice that having stopped the car and keeping my foot on the pedal it goes right to the floor.
I would think this is air in the system but the garage say no.
So.. should the pedal go to the floor or not??
x 6954
Re: C5 Brakes
Pop your VIN up first so we know exactly what you have.
There is a primary and secondary braking circuit and the secondary circuit needs the a diagnostic tool like Lexia to bleed the system correctly (under the ABS / ESP system menu in Lexia).
If your garage doesn't know this then that's worrying. If you don't have a Lexia yourself, you may be better off getting a dealer to bleed it properly and avoid mickey mouse outfits in future. Looks like they have allowed air in the system / or the seals in the master cylinder have inverted....
rogerc5
Re: C5 Brakes
Thanks, The garage has been ok for several years, but only bled the one new caliper on my request
The vin is VF7**************[VIN obfuscated, can be read by forum staff]
x 6954
Re: C5 Brakes
There's no such thing as bleeding one caliper - if the system has been opened, then air will have entered the braking system and it has to be properly bled for safety reasons alone.
Ok, so this is a MK I C5. What are your intentions? I can put a bleeding procedure up here - but you will still need somebody with a Lexia to bleed the secondary circuit - you have ABS with ESP on this vehicle, so won't help if you are not doing this yourself. Let me know anyway.
rogerc5
Re: C5 Brakes
Thanks Marc
I feel vindicated!
There's another Citroen specialist nearby so I'll go there next week.
x 2941
Re: C5 Brakes
Not Citroen but the same system.
Reason: YouTube link
rogerc5
Re: C5 Brakes
That's great thanks-- I can make sure the garage follow the procedure. I thought it was just a Citroen thing.
