Can anyone help in rectifying our faulty air con
C4 Picasso. LEFT HAND DRIVE
It blows cold for a few mins then turns to hot
Regardless of temp selected
It is only faulty on the drivers side. L/H side
Passenger (R/H side ) is always ok
Any help is appreciated
Our car is in Spain and I don’t particularly want to go to a main dealer. Unless I really have to?
Steve
LHD C4 Picasso
- x 1461
Re: LHD C4 Picasso
Is the cold/hot transition related to the engine warming up? Does it revert to cold if you start the car with a hot engine?
It is most likely to be a faulty flap motor or broken temperature control flap. There is some info on access here: viewtopic.php?p=560871#p560871
Stevelove1966
Re: LHD C4 Picasso
Hi. And thanks for the reply
It seems to be regardless of engine temp that it fails when it wants
Sometimes you can hear a faint click/clunk. Then you know it’s going to start blowing hot.
I do agree about the motor failing as it seems a Very common occurrence
I was wondering where to locate the faulty motor? As it’s LHD is it in a different location ? Or am I being daft?!
