Dear Members,
My Gearbox is fault.... I am planning to replace the GB.
Need some advice on 16V GB
On my Zx 16v GB number
BE3 5FG
I will replaced with this
GB BE3 6FG.
Will there any different in gear ratoi
Citroen Zx 2.0 16v Gearbox Ratoi
Kumar9989
- x 3
Xantia 96 2.0 petrol auto
- x 6957
Re: Citroen Zx 2.0 16v Gearbox Ratoi
You'll need to put your VIN up here - as those are not the only references - I can't go by those.
Kumar9989
- x 3
The Vin num
- x 6957
There is very little info I have on this given that it's 25 years old now - but I know that there was a change during your build date for the 2nd gear ratio on the BE3 box for the XU10J4 engine. The gearbox reference for the 2lt engine I think changed from 20 CL 46 (20/37) to 20 CL 80 (23/43).
As for the the 5 and 6FG - I think these relate to the final gear and I can't find any references to those - but on the BE3 they have a push rod instead of cable operated - so I would doubt the other one would fit.
Kumar9989
- x 3
Happy New year 2020
Just to share information on the Gearbox.
Have replaced the GB with BE3 6FG.
It's work but the gear Ratio is slower
The respond is a bit slower then
The other Gearbox BE3 5FG
Thank you
Thank you
