Peugeot 407 V6 Smells of Petrol
Franchute13
Unread post by Franchute13 »
Hi.
I have a strong smell of gasoline in the engine area.
I see that the fuel lines are divided into 2, one for each injectors ramp. I can't see if the injectors lose.
In the pipes I don't see a leak.
What steps do you recommend to follow to find the leak?
Thank you!
Franchute13
Re: Peugeot 407 V6 Smells of Petrol
Hello!
I found the problem.
Injector # 2 loses fuel by oring with the ramp!
Regards.
x 3306
Well done on finding it, and letting us know. :D
Franchute13
Thanks Hell Razor5543!
I took some pictures but the leak is not noticeable!
Comment that when the car comes into contact (before ignition) the engine area is full of smell.
I was watching videos of how to change the orings to the injector.
I understand that:
Pressure must be drawn from the circuit, to do this:
1) Remove the fuse to the gasoline pump.
2) Start the engine until it turns off. Retry to burn.
3) Open the fuel cap.
Then, disconnect the battery.
Disconnect the fuel inlet to the ramp.
Disconnect the injectors.
Remove the screws from the ramp.
Carefully remove the ramp.
Carefully remove the injector, grasping it completely with your hand and making movements.
To change the orings, be careful not to hurt the injector head.
Does this procedure seem correct? Any suggestions?
Cheers
Franchute13
Hi.
Well, the problem is not the orings, it is the fuel rail. It has a micro crack, at first glance it is not visible but when there is pressure it loses fuel.
Franchute13
It seems to be a common problem.
3 Peugeot 407 v6 (in another forum), the 3 leaking fuel in the injector # 2 !.
