New Posts
moizeau
x 423
New Posts
Unread post by moizeau »
Crikey, you've go to be quick, how old does an 'old post' have to be? In the evening about 2 hours?
Pete
x 6950
Re: New Posts
Yes, a hive of activity here :-D
x 1481
Re: New Posts
Unread post by xantia_v6 »
If you are talking about the "new posts" search, it finds posts that have been made since you were last active on the forum, which (due to the way phpBB sessions work) can be an hour or two if you are a habitual user.
I generally recommend not using the "New Posts" search, I use the "active Topics" search, new posts are obvious in this search because the topic icons are red rather than grey.
moizeau
x 423
Re: New Posts
Cheers for that, I thought, 'new' meant recent to all, not just to me. Active topics it is then. Thanks for the clarification.
Pete
x 1952
Re: New Posts
Unread post by Paul-R »
xantia_v6 wrote: 21 Nov 2019, 20:47I generally recommend not using the "New Posts" search, I use the "active Topics" search...
Thanks for that tip. I'll be using Active Topics from now on as it helps to keep track of previously read posts.
van ordinaire
(Donor 2017)
x 400
Re: New Posts
Just more confused than ever :cry:
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
x 3298
Re: New Posts
moizeau wrote: 21 Nov 2019, 20:28 Crikey, you've go to be quick, how old does an 'old post' have to be? In the evening about 2 hours?
It is 'old' the moment you have read it, antique when you have read it twice, ancient when you have read it five times, prehistoric when you have read it ten times, and kick starting the Big Bang when you read it twenty times!
Does that help? :D
x 8163
Re: New Posts
Hell Razor5543 wrote: 23 Nov 2019, 18:54
Does that help? :D
I'd have to say James, that explanation was about as useful as an ashtray on my Suzuki RF900 !! :-D :-D
x 1481
Re: New Posts
The simple way to not miss anything, while avoiding reading the same posts again and again...
  • Click on the the Active Topics button at the top of the screen
  • The results page will have some topic icons that are pink and some that are grey
  • Ignore the grey ones, because you have already read the latest post in that topic. (If you click the grey icons, it will take you to the last post in the topic)
  • Click on a pink topic icon, and it will take you to the first post that you have not yet read in the topic
van ordinaire
(Donor 2017)
x 400
Re: New Posts
Can't help thinking this is a solution to a problem that doesn't exist - or am I missing something?
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
'99 Cadillac STS :|
x 3298
Re: New Posts
mickthemaverick wrote: 23 Nov 2019, 19:04
Does that help? :D
You mean to say you HAVEN'T got one?!?
x 8163
Re: New Posts
Hell Razor5543 wrote: 24 Nov 2019, 18:51
Does that help? :D
Indeed I havn't, I gave up smoking in 1990 so saw no need for it anymore!! :-D
