Hi all,
I have bought a Berlingo 1999 DW8 for work but, the pump recently starts to leak. How to replace the whole pump?
If yes what are the instructions for it.
Berlingo injection pump change
jsp
- x 12
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
jsp
- x 12
Re: Berlingo fuel pump change
There is a leak somewhere but, not really visible where it comes from.
It's a Lucas pump
It's a Lucas pump
My Citroens update:
jsp
- x 12
Anybody has the instructions for this? I have another pump but, this one doesnt have the timing mark?
My Citroens update:
- x 6945
Re: Berlingo injection pump change
If you want a pump fitting guide, I'll need your VIN for the Berlingo.
jsp
- x 12
65250186
My Citroens update:
jsp
- x 12
I have changed the pump now, but it wont go over 50mph on wot anything to adjust?
My Citroens update:
- x 6945
19206L was for a new one and 1921F1 was the part for an exchange one.
- x 1489
How did you set the timing? Not sure on a DW8, but you usually need a dial gauge. Not enough advance usually results in lack of power and quiet running. If you don't have the dial guage you could just try advancing it a bit by rotating the pump (towards the engine I think) to see if that improves it.
jsp
- x 12
If it clacks too much is there too much advance?
My Citroens update:
jsp
- x 12
On the VE pump you need a dial guage on the Lucas the dial hole is blanked off.RichardW wrote: 03 Dec 2019, 10:56 How did you set the timing? Not sure on a DW8, but you usually need a dial gauge. Not enough advance usually results in lack of power and quiet running. If you don't have the dial guage you could just try advancing it a bit by rotating the pump (towards the engine I think) to see if that improves it.
My Citroens update:
