Berlingo injection pump change
jsp
x 12
Unread post by jsp »
Hi all,
I have bought a Berlingo 1999 DW8 for work but, the pump recently starts to leak. How to replace the whole pump?
If yes what are the instructions for it.
jsp
x 12
Re: Berlingo fuel pump change
There is a leak somewhere but, not really visible where it comes from.
It's a Lucas pump
jsp
x 12
Anybody has the instructions for this? I have another pump but, this one doesnt have the timing mark?
x 6945
Re: Berlingo injection pump change
If you want a pump fitting guide, I'll need your VIN for the Berlingo.
jsp
x 12
65250186
jsp
x 12
I have changed the pump now, but it wont go over 50mph on wot anything to adjust?
x 6945
jsp wrote: 30 Nov 2019, 02:4665250186
19206L was for a new one and 1921F1 was the part for an exchange one.
x 1489
How did you set the timing? Not sure on a DW8, but you usually need a dial gauge. Not enough advance usually results in lack of power and quiet running. If you don't have the dial guage you could just try advancing it a bit by rotating the pump (towards the engine I think) to see if that improves it.
jsp
x 12
If it clacks too much is there too much advance?
jsp
x 12
RichardW wrote: 03 Dec 2019, 10:56 How did you set the timing? Not sure on a DW8, but you usually need a dial gauge. Not enough advance usually results in lack of power and quiet running. If you don't have the dial guage you could just try advancing it a bit by rotating the pump (towards the engine I think) to see if that improves it.
On the VE pump you need a dial guage on the Lucas the dial hole is blanked off.
