C5 Tailgate Problem
tc5
C5 Tailgate Problem
Unread post by tc5 »
Can anyone please give me the part number for the anti pinch sensor for the electric tailgate 2010 C5 tourer exclusive Tailgate openes will not close Lexus showing Fault R/H anti pinch sensor
x 6957
Re: C5 Tailgate Problem
I'll need your VIN - these are not sensors as such, they are built into the trim / seals. Before doing that though, I suspect you may have a wiring issue - it is known that these can cause issues at the area where the wiring enters the top of the tailgate. I'll try and locate a similar post.
viewtopic.php?p=592260#p592260
and later the fix:
viewtopic.php?p=594753#p594753
if this is the same issue....
tc5
HI Marc,
Vin no. VF7**************[VIN obfuscated, can be read by forum staff]
tc5
Could be a wiring problem, will need to check in a few days as car is at the local garage having a new ERG fitted.
tc5
Hi, sorry for the delay in replying but problem solved! New ERG fitted faults re set tailgate now OK!!
