The remote locking on my 93 k plate 405 doesn't work. Have tried new batteries in the plipper to no avail. Any ideas on cheap repairs?
TIA Doyle
405 REMOTE LOCKING
Dave Burns
- x 3
If it's an infrared system you can see if the LED on the plipper is working by pointing it into a digital camera or camcorder, as long as it has a electronic viewfinder it will display an infrared source, check with a known good IR source.
Or you can get a coated card from electronic shops that will reflect IR in the visible spectrum, it wont tell you if the code being put out is ok but it's a start.
Good luck
Dave
Good luck
Dave
