Juddering on take off
Oletimer
Just got a 2007 C4 Grand Picasso 2.0L HDi. (Auto/Manual)
It's in not bad condition and drives really well. (You get the feeling there's a 'but' in there somewhere?)
Yeah, there's a couple of buts:
1, From a standing start there's a judder for a few seconds then it smooths out and all is fine, no noises, nothing...
- if you increase the revs a bit it doesn't judder from a dead start, it just takes off (and I mean quick). Open to suggestions...
2, On the central console the miles before refuel and mpg and end journey operate, but the MPG and distance to end doesn't show any readings? Any suggestions...
3, The dashboard gloveboxs are crap, what can be done to sort them out - or is it only renew?
4, There's a plastic trim on the back that covers the number plate lights, it's been glued before but it's falling off again - any suggestions (the new bit is £140)
5, I think it needs tracking, it's veering to the left. It's only just gone thru an mot too?
Any suggestions gratefully received
George
George
If it ain't broke - don't fix it!
- x 1484
dave_xsara
- (Donor 2021)
- x 10
Re: Juddering on take off
1. Gearbox mount?
- x 1484
Anyway, I'm thinking this is an EGS box? I would say:
1. Might just need the clutch adjustment setting - needs a Lexia really, but you can do something by pulling away hard a few times from a standstill to let it auto calibrate. If not, then new clutch time....
2. Don't know, can you post a pic - you have to manually enter the miles to end of journey. Which MPG readout is not working?
3. I suspect renew only - what do you mean by crap, they were always a bit flimsy! Should be able to get some from a lower mileage scrapper
4. This got broken on ours, not sure how, suspect it got reversed into. I glued it, but as it is used to lift the tailgate it's easily broken, again I suspect a scrapper is best option - it's not too hard to remove.
5. Could be - tracking not checked at MOT - it will pass as long as tyre wear is OK.
Reason: Deleted stuff related to a completely different topic
Oletimer
Thank you for those helpful replies:
I'm still in the 'buyers option' stage and was wondering if it's worth taking on, tho to be honest I think he's asking too much for it at 1500.
What's a good guess at it's sale value?
Done about 120k, general condition is ok, it does drive nice with no surprises, it's just had a suspension overall with new pump etc. MOT 02/10/2020
All the electrics work as they should.
Would you pay 1500 for it or what would be your offer?
Cheers
George
Cheers
George
admiral51
- (Donor 2026)
- x 391
2. if like my C4 2005 there is a push switch on the end of the wiper stalk which will switch between modes, date/trip etc
5. Soft tyre maybe ?
- x 1438
If it has an EGS transmission, your best move by far is to walk away. There are much more enjoyable ways to throw good money after bad.
- x 3566
Wise words !
Wise words !
Omer40
I had the same issue, juddering, new clutch sorted it out. Good luck.
Oletimer
Thanks for the input, I am very grateful of any input from your experiences re: Citroen C4's (my last Citroen was a P reg Xantia - which was a lovely car)
The learning continues...
I've been driving it a bit more and have got 'used' to how it drives, so much so, that the judder isn't as bad as first appears...
Initially I would pull away very gently, (sort of 'ghosting' away - the way you'd expect a Rolls to do) the car would move forward a little then seem to not drive, followed by drive, until the revs increased a little when it would drive smoothly. Once driving it would be beautifully smooth.
I played around with take off revs and found that it would drive smoothly from a start if I gave it a few extra revs - not gunning it, just a small increase.
I was told by a mechanic friend to change the gearbox oil because he thought the level might be low.
Otherwise I'm chuffed with comfort etc, it really is a nice drive - gear changes could be a fraction earlier but I'm not sure what the parameters are, I would prefer changes at about 2k but maybe that's a little low (?)
Trip-tronic works beautifully, it's certainly faster than me but I'm an ole codger so maybe that don't count.
I've noticed the 'miles to refuel' reading is a bit bizarre: I put £25 in and that brought it to the half tank mark, readout: 264 miles to refuel. Went about my business and 26 miles later the readout was down to 224.
Do I need to buy the man in the tank a new calculator or is this normal for French mathematics?
I was led to believe it does approx 600 miles on a tank, is this about right or was this 'salesman' talk?
It's going to Castra Verde soon and an idea of expected economy would help. (My old Fiat Multipla would normal manage a very reasonable 50mpg on the same trip)
I've got to replace the glove box lids - they're looking sun burnt and twisted.
I need a replacement strip for the back door, this ones been beaten up, where is a decent supplier to be found?
I think that's enough to be getting on with, any suggestions or leads to part suppliers would be helpful
Thanks in advance
George
Thanks in advance
George
- x 1484
Miles to refuel works on the average of the last few miles consumption, so if you added fuel after a long run with good economy, then did a load of town driving the range would go down.
Long range economy will depend on how you drive - if you take it easy, then you might get towards upper 40s. Tank on these is only about 50l, so I would expect 500 miles to a tank max.
I was going to say you could buy new glove box lids, but they are £300 EACH
. So perhaps not
I would look on e-bay for one the right colour that is getting broken, then get the lids and the boot strip off that.
Oletimer
Richard W:
Thank you for your input - not having owned a Citroen for a long time I'm out of touch with their foibles.
Please forgive me if I bend your lug-holes when any surprises crop up or if I'm in the 's**t-hits-fan' department.
I do all my own spanner bending and can usually make it work - one way or another.
When faced with a 'new' breed and 'new' problems help is a god send and I will always be grateful for experienced input.
Would you kind enough to explain the clutch adjust routine please? What is a Lexia?
You're right about that strip not being hard to remove - look at it and it falls off - the only things holding it on are those 2 white plastic pins on the ends,
all the square bits seem to be broken.
I will take onboard your remarks and say a very big thank you.
Cheers
George
Cheers
George
OnlineHell Razor5543
- x 3300
The Lexia/Diagbox equipment are used to diagnose and resolve faults in the PSA range of vehicles. As the PSA group are French they are a law unto themselves! Normal code readers cannot understand them! You need a reasonable laptop (running a 32bit O/S, such as Windows XP or Windows 7), and the Lexia equipment. If you decide to get it PLEASE make certain to get one that has the full opto-chipset (some of the cheaper clones don't and cannot work with cars such as the C5). There is a company called Easy Diagnostics who do a very good version with the most current version of the software recommended, but it is not cheap (around £150, but use it a few times and you will save yourself money, as a dealership may charge £50 per session).
https://www.frenchcarforum.co.uk/forum/ ... hp?t=60113
- x 1484
Assuming the trim strip is item 12 in this diag, then it's supposed to be held on with 6 bolts!!
There's loads up for breaking on e-bay in different colours - find one that's the right colour and get the strip off it.
Oletimer
Thanks Richard, that's exactly what it is (12) it doesn't look like they wasted too much plastic on the fittings. May I ask: is there a download for a decent workshop manual for the C4? I do like to work from a decent manual.
Dunno if I can stretch to a diagnostics kit yet, I'll put it on me wish list tho.
George
George
