Odd techy messages using forum
Forum News, Announcements and any issues you're having with the forum
Moderator: myglaren
x 1881
Post by NewcastleFalcon »
This particular session and on some other sessions I have noticed some techy monitoring/error type messages appearing in bold at the top of my screen. Here's one
[phpBB Debug] PHP Notice: in file [ROOT]/ext/v12mike/imageredirect/event/listener.php on line 53: Undefined offset: 1
I seem to be able to complete what I need to do.
Also occasionally the quote function when quoting other users posts for a reply sometimes fails, although I dont have the screenshot evidence for this, but should it occur again I will capture it if I can.
Donor 2021
x 1337
Re: Odd techy messages using forum
Post by bobins »
Same here.
x 1728
Post by myglaren »
I just got that but it disappeared almost instantly.
I had a fail to quote yesterday too.
x 512
Post by xantia_v6 »
Thanks for the reports. I turned on some extra debug switches while checking something else yesterday. Those warnings are normally hidden.
I will take a look at the source of the warnings, then switch the debug off again.
Can you give a link to a page with each of these problems? I think I know what causes the debug warning, but need to check.
Can you describe what happens in a "failure to quote"?
Donor 2021
x 1510
Post by Hell Razor5543 »
I just had them when I was looking at "Picture of the Day" and clicked on the top of page button (but not when I did it on this page).
x 512
Post by xantia_v6 »
OK, I think that I have tracked down and fixed the warning message.
Let me know if you see the "failure to quote" again.
x 1728
Post by myglaren »
This one:
myglaren wrote:
22 Aug 2019, 23:29
[ quote=NewcastleFalcon post_id=617351 time=1566511042 user_id=8657]
Quote function seems to be broken.
The Lysekil procession is just one of many. Swedes are quite fond of American cars.
[/quote]
I have broken the "Quote line to display it as it appeared then.
x 512
Post by xantia_v6 »
Sorry, I am confused. Is the problem repeatable? if so can you tell me how to reproduce it? Can you give a link to an actual post on the forum where it is apparent?
x 1881
xantia_v6 wrote:
26 Aug 2019, 07:01
Thanks Mike I will let you know if it happens again. May relate back to "the post does not exist" problem which was fixed.
If I recall right the "quote reference" would come across, but none of the content. So for your post I have quoted above and worked perfectly, this would have been transported to the "compose a post screen" but nothing else/no content.
xantia_v6 wrote:
26 Aug 2019, 07:01
x 1728
Post by myglaren »
xantia_v6 wrote:
26 Aug 2019, 07:56
It hasn't repeated although I have tested it a few times.
It's on this page near the bottom.
x 1728
Post by myglaren »
Went back to Neil's post and tried again:
Neil's post.
POD page 214
x 1881
Its certainly reproduceable by me from that post mentioned by steve. It does link to a large gallery of images if that has anything to do with it.
this is what I got Edit Same as Steve above.
screenshot
screenshot
