C5 X7 front end loose
Viitonen
(Donor 2022)
x 11
Unread post by Viitonen »
Hello,
I have a 2009 hdi sedan X7. My front end has made this annoying squeking noise for several months. It comes from the lower arm bushings from both sides. When I spray wd40 or similar there it stops the noise for a while. So, I know the arm bushings are in poor shape. When I'm driving to a curve rather fast I can feel the front end is somewhat loose more than it used to be. Is this caused by the bushings?
Next thing will of course be the lower arm change anyway. What do I expect to do? Are there any howto's around to do that? Thank you!
barryanto
Re: C5 X7 front end loose
Unread post by barryanto »
can you post a diagram of the parts your talking about please?
x 6954
Viitonen wrote: 31 Jul 2019, 04:48 Hello,
Refer to my post here - if it's the same thing:
viewtopic.php?f=3&t=57486&p=615570#p615570
Viitonen
(Donor 2022)
x 11
Thank you! They are the red arrow ones 👍
