Citroen C5 Estate - Any Good?
doctle
- x 223
I can buy a Citroen C5 estate for quite silly money. It's a 1.6 HDi seller says it needs tyres and wishbones. I like the look of it but I have heard stories about them being high maintenance. Any comments welcome, thanks!
Oh buggle
OnlinePaul-R
- x 1938
Re: Citroen C5 Estate - Any Good?
What year? Mk2 or Mk 3 (X7)? How many miles? Any MOT on it?
doctle
- x 223
It's 2007 so MK2 I think. No test tbh I just got a call from a friend that's selling it. €350 so about £300 no idea if mileage it was being driven until recently
Oh buggle
- x 3296
It will be a Mk2 (otherwise known as the facelift), but you will have to see what the service history is. There is (with some 1.6HDi engines) a known design flaw that allows sludge to build up, and for the filter in the turbo banjo bolt to get blocked, resulting (over time) in a failed turbocharger.
- x 1996
GREAT CARS....so big and so so very comfortable.
Why worry at 300euro.....just throw 2 Oil changes in over 200 miles, tighten the injector bolts and drive it.
The only other common problem are the rear arm bearings, that is a "CLACK" from the BACK over speed bumps (maybe why he says wishbones), do not confuse with a drop link which is a noise from the front....cheap
It is hard to judge a 300Euro car from "common faults", just make sure it does not smoke, has no lights on and does not CLACK at the back over bumps.
- x 3296
The space in the back is enormous. I swear that, on occasion, I have heard an echo when loading the boot!
- x 1996
Pardon....Pardon....Pardon....Pardon....Pardon....Pardon....Pardon....Pardon....pard....par....pa....p
OnlinePaul-R
- x 1938
My old Mk1 creaked at the back through two or three UK MOTs and still passed. I bought the bearing kits fully intending to change them but never got around to itStickyfinger wrote: 29 Jul 2019, 07:01The only other common problem are the rear arm bearings, that is a "CLACK" from the BACK over speed bumps (maybe why he says wishbones)...
... and does not CLACK at the back over bumps.
- x 1746
There's a long history of Citroen rear-end creak and clack: C15, BX . . .
Good to know that these traditions are being maintained.
doctle
- x 223
He did say the engine light is on. I'm going to see it Wednesday I will report back then
Oh buggle
OnlinePaul-R
- x 1938
Any bets that the DPF and/or Eolys level need looking at for this?
What are the regs for the Irish equivalent of the MOT for warning lights?
- x 1240
I had a couple of Mk 1s, certainly big but not up to the standard of previous hydropnumatics which I drove for 30 years. The hydractive one is better for ride but my 2.0 Hdi gave a dreadful ride even after I changed the spheres and trailing arm bearings.
- x 1996
Then it was broken,. My Mk1 was a gentle as a feather....lovely old boat of a thing. (Non HA+ 2ltr)
- x 8117
Stickyfinger wrote: 29 Jul 2019, 14:50 Then it was broken,. My Mk1 was a gentle as a feather....lovely old boat of a thing. (Non HA+ 2ltr)
I'll second that. I'm on my 3rd MK1 with a previous 2.2HDI Estate and a 2.0 HPi (we all make mistakes!) and all three have been/are as smooth as silk. Every bit as nice to drive as my 2 XM's were but not quite as nice as the Xantia Activa
doctle
- x 223
Paul-R wrote: 29 Jul 2019, 09:11 Any bets that the DPF and/or Eolys level need looking at for this?
Check engine, abs. srs lights are a fail, we call it NCT, national car test
Oh buggle
